Ir para o conteúdo principal
The Mac mini family was first introduced in January of 2005.
1251 Perguntas Visualizar todos
Type E power cable for Europe
I just got a 2012 Mac Mini for my friends in Europe. They would require a Type E power cable and I was wondering where I'd go about getting it?
I'm not sure an adapter would be the best option for longterm use of a computer that's always running. Suggestions?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
Not to worry you have a few options here.
First your mac uses a two prong non-polarized electric razor cord 2.5Amp @250Volts {15Amp @ 120Volts} Type C. Which allows you to use standard travel AC adaptors.
The best solution is getting a Type C power cord. Not a Type E as you don't need it, there's no ground service present in the Mac mini, or a Type F as you don't need polarization either.
The correct cord is a IEC C7 (at any angle) with a CEE7 on the other side.
Here's a good source for any cord need SignalandPower.Com
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thank you Dan. You've been very informative.
por
Adicionar a sua resposta
Erik será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 902
