Car is over heating
Car over heats, but not consistantly. It will go weeks without overheating, then overheat two days in a row. I have changed the thermostat and the coolant is full.
Esta é uma boa pergunta?
Have you had the radiator flushed (may need to do this more than once)? Either you have some junk blocking the core and/or hoses. Lastly, your pump is going or your core is in trouble.
Esta resposta foi útil?
If it is intermittent I would suspect the radiator. It doesn't take long to blow a head gasket if the engine over heats so it's best to find the fix before it gets really costly. Jack
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 6
Duração total: 1,432
