Ir para o conteúdo principal
Model A1297 / 2.66, 2.8, 2.93, or 3.06 GHz Core 2 Duo processor
Broken Hard Drive Connector
Macbook pro 17 A1297 Damaged Hard Drive Connector
My Hard Drive Connector attached to the logic board is broken, is it possible to repair this or can i use the Unibody Laptop Dual Drive device as a boot hard drive replacement
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Solução escolhida
You can go with this optical bay adapter, put your hard drive in it and boot: [produto vinculado ausente ou desativado: IF107-079]
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
Putting the drive in an external case is a good workaround. Soldering logic board components is an advanced DIY project. You might be able to find an electronics/computer repair shop that could reattach the connector if it's not too damaged.
If this answer was helpful please remember to return and mark it Accepted.
Pontuação 1
Adicionar a sua resposta
Richard Flemming será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 3
Ao todo: 142
