Turn off oil change warning
I have changed my my oil in my 2012 Jeep Wrangler but now I need to know how to turn off the Oil Change warning that appears every time I start the engine.
Esta é uma boa pergunta?
1. Turn the ignition switch to the ON position (Do not start the engine).
2. Fully depress the accelerator pedal slowly three times within 10 seconds.
3. Turn the ignition switch to the OFF/LOCK position.
Esta resposta foi útil?
I'm not positive, but you probably need an OBDII reader of some kind. I have one that plugs in to my iPhone and uses an app called "DashCommand" to read and clear codes and warning lights, but there are many standalone units that also will solve your problem.
Últimas 24 horas: 13
Últimos 7 dias: 98
Últimos 30 dias: 425
Duração total: 13,906
1 comentário
It did not work on my 2008 Rubicon.
por Baker311
