Ir para o conteúdo principal
I have a CD-Rom stuck in my DVD/CD drive.
I press the eject button and the CD remains in the dirve
Esta pergunta é pertinente?
Pontuação 1
1 dos comentários
did you look ito the manual to see the ways of ejecting the CD - I would think you did ...
por
Adicionar um comentário
4 respostas
Solução escolhida
turn off the computer then turn it back on and as the computer is coming back on hold left click down
ps- press the power button then immediatly hold down the click button, don't wait for anything
Esta resposta foi útil?
Pontuação 2
if above did not work here's another thing to try: boot the machine into Open Firmware by doing the following:
1. restart the machine, and immediately hold down these 4 keys simultaneously: Cmd-Option-O-F (that's a letter O, not a numeral zero before the F)
the machine should boot but show a white screen instead of the normal Mac OS
2. at the prompt, type: eject cd then press Return
this should hopefully eject the disc and show OK on the screen.
3. at the prompt, type: mac-boot then press Return
your machine should boot normally
Pontuação 1
Check this hint:
http://www.macosxhints.com/article.php?s...
Pontuação 0
Actually, one more thing, this has worked whenever I've had stuck disks, verify the hard disk, and run the drutil -eject shell command at the same time.
Pontuação 0
Adicionar a sua resposta
dski será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 2,162
