Ir para o conteúdo principal
Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Perguntas Visualizar todos
Second Disk shuts down while transfering files
I have installed a second HDD on my Macbook pro 13 by using an optical bay hd enclosure!
After doing everything ok and starting to transfer files from the primary to the new one it stops and displays a message like "the disk was not properly ejected .... " and in order to see it again i have to remove it and reinstall again! Also for some reason the WI-Fi and the Bluetooth stopped working!
Any ideas????
Esta é uma boa pergunta?
Pontuação -1
1 comentário
Did this solve the problem? I'm having only the issue with the "Disk Not Ejected Properly", but I know it is not the Energy Saver issue as I have always had that unchecked.
por
Adicionar um comentário
1 resposta
Solução escolhida
From System Preferences Energy Saver: remove the √ from in front of "Put the hard disk(s) to sleep when possible".
Recheck your the connections or the socket for the wireless card.
Remember to return and mark accepted the answer that best solves your problem.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
George Martos será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 74
