Replacement Screen will NOT Stay Down. Can I get stronger adhesive?
Hello everyone!
I've repaired these 4th Generation iPod touch's by replacing the display before, and I consistently have the same problem with doing it.
After I'm done with everything, the 3M adhesive strips simply DO NOT keep the glass down. The screen will always pull away and lift off after about 10 minutes. The glass parts are clean and free from hand oils and it just doesn't stick. :(
My next option is to epoxy the display on, but I don't want to do that because if the iPod breaks again, I won't be able to remove the display.
Is there an even stronger option for adhesive strips? Anyone know?
Thanks so much! :D
Esta é uma boa pergunta?
