Ir para o conteúdo principal
Quinta Geração do Iphone. A Reparação deste dispositivo é correta, requer ferramentas especificas e paciência. GSM/CDMA/16, 32 OR 64 GB/Black or White.
2193 Perguntas Visualizar todos
Got a screw that is striped
Hi all I have a problem and was wondering if anyone else had this.
Was repairing a 4s today and the screw on the battery connector was completely striped and I was at it for a hour with no joy. I've heard of people using a little bit of glue but I don't think it's possible as the screw seems to tight.
Was wondering if I let the battery die could I take out the motherboard and battery and the speaker in one peice as the reception wire is attached to the motherboard aswel.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Solução escolhida
i bought these special screwdrivers here, they helped me more than once
Precision Screw Extractor Set
Imagem de Precision Screw Extractor Set
Produto
$24.99
Esta resposta foi útil?
Pontuação 0
Had the same problem with removing the back panel lol
You have no choice...
I brake the back panel one time the other time the screw
Pontuação 0
1 comentário:
Heheh no absolutely no!! Stripped screw are a big problem... Your idea is the best one;-)
por
think I will have to remove motherboard battery and speaker don't think it's worth breaking the motherboard over it..
Pontuação 0
Adicionar a sua resposta
con será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 143
