Ir para o conteúdo principal
The Motorola Droid RAZR Maxx is a version of the Droid Razr carrying a higher capacity 3,300mAH battery.
23 Perguntas Visualizar todos
replacement glass for this same phone
same model phone it fell and glass on front cracked it still works, no problem with touch response just glass replacement IS THAT POSSIBLE MYSELF AND HOW ASAP CAN I BUY IT NOW FROM YOU.?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
HERE is a YouTube video of disassembly. The screen assembly is available but is expensive.
It seems you cant separate the digitiser from the LCD but you can apparently replace the Front Glass alone.
Front Glass
Also Out of Warranty Repair
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
PHIL será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 3,577
