Ir para o conteúdo principal
Model A1288 / 8, 16, or 32 GB capacity
451 Perguntas Visualizar todos
My home button is jammed down
Please help, when I try to press my home button it won't work. I can't even really press it down it will just stay stuck down. Ife tried using alcohol but that didn't work. Then I dissembled the glass from my iPod and i'fe searched if i could find anything bad. When I take the button itself (so without anything around it, just the round little thing) i will see the 'real' button witch it touches. If i press this it will just act as a normal button and spring back. But the thing above that doesn't do that, it will stay just down.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
Hi Norberz,
You might want to take a look at this video clip. For a better view, look at this. Is your golden home button spring still in place?
Steffen
Esta resposta foi útil?
Pontuação 2
1 comentário:
i am not going to risk it
por
try opening the back of the ipod and push the home button up... if it works and u push it down again and it gets stuck then look at the video clip
Pontuação 0
Adicionar a sua resposta
Norberz será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 13
Duração total: 24,487
