Ir para o conteúdo principal
The BlackBerry Z10 is a touchscreen-based smartphone developed by BlackBerry, previously known as RIM.
72 Perguntas Visualizar todos
BB Z10 dropped into water and the motherboard got bad.
My BBZ10 dropped into water by a friend and I didn't know until the phone went off. It was discovered by the seller that the motherboard is bad.
My problem is how can I get a new motherboard to replace it?
Thank you
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Pergunta mais útil
Sadly you're stuck with a damaged phone or you can buy a used z10 and swap the boards.
Esta resposta foi útil?
Pontuação 2
Hello there Omoluabi! I know your question is a few months old, but I thought I'd drop in and offer some insight. The cheapest way to find a replacement board is probably going to be purchasing an identical model from ebay that is damaged. I found the following BBZ10 that has a defective screen, and that's all (So he says). It's cheap as dirt and a WHOLE lot cheapter than a replacement phone.
Busted Z10 on Ebay
Best wishes!
Pontuação 0
I dropped my Z10 in water mixed with some bleach is there is a chance it will work... I love my blackberry so upset ...please help...
Pontuação 0
Adicionar a sua resposta
Omoluabi será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 2,639
