Ir para o conteúdo principal
The PowerBook G4 Titanium Series was initially announced at Steve Jobs' keynote at MacWorld Expo in January 2001.
130 Perguntas Visualizar todos
Limits on hard drive replacement capacity 128 gb
I have old 80 gb HD. I want to repalce with larger capacity ATA HD. I would like as much as possible 320gb Western. but I read some disclaimer that some older PowerBooks will only recognize up to 128 gb with out other commercial software? Can I partition the new HD to get around this limit? What is the other commercial software?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
You can partition the drive into multiple partitions < 128GB, and it should work fine.
Esta resposta foi útil?
Pontuação 1
You'll have to do the partitioning on a newer machine and then install it in the older machine.
Pontuação 1
1 comentário:
Thanks a bunch. looks good.
por
Adicionar a sua resposta
Doug será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 6
Duração total: 1,167
