Ir para o conteúdo principal
Quinta Geração do Iphone. A Reparação deste dispositivo é correta, requer ferramentas especificas e paciência. GSM/CDMA/16, 32 OR 64 GB/Black or White.
2193 Perguntas Visualizar todos
Water damaged iPhone 4S issues
Iphone went through the laundry, it already had a broken LCD. i bagged it in rice for a few days, while waiting for new LCD to arrive. I took the phone apart to replace the LCD and a quick visual inspection showed no signs of damage or corrosion. i replaced the LCD and put it back together with a new battery. It turned on, the LCD was a little jumpy at first then it settled down. Everything seemed to work ok except the colors were a little off and it would not display the ringer volume bar when adjusting the volume. the volume would adjust it just didn't show it. I took it all back apart again and got out the loupe to check the board and contacts more closely. found a little corrosion on one contact and cleaned it with a small paint brush and 91 Iso and then cleaned the whole board according to guides here, including immersion of the board in iso. Let it dry thoroughly and reassembled. Now all i get is a white/gray screen. It worked nearly perfectly yesterday, now nothing. Replacing coils etc. are way beyond my ability. I will try swapping parts with another iphone over the next couple days to try to narrow down the problem. If anyone could suggest a different solution it would be appreciated.
Esta é uma boa pergunta?
Pontuação -1
1 comentário
after a thorough ultrasonic cleaning, no signs of life from the display. phone seems to work, just can't see anything. putting on the shelf for another day, or month....
por
Adicionar um comentário
1 resposta
Solução escolhida
Try to pop up the metal covers that covers the chips from the logic board.. check for corrossion you can see..
There is also corrosion you cant see just try to clean your logicboard up with your brush very good.. use 91 iso not to much, double check the lcd connector points for corrosion and clean this..
Try to assembly the iphone with only a dock connector and lcd screen connected to the logicboard and put the cable in the dock connector to power on the phone...
I have a ultrasonic water damage machine that makes the repair much easier :)
good luck !
Esta resposta foi útil?
Pontuação 0
1 comentário:
thanks, i am going to run it through an ultrasonic today and see if it helps.
por
Adicionar a sua resposta
jef será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 260
