Ir para o conteúdo principal
Quinta Geração do Iphone. A Reparação deste dispositivo é correta, requer ferramentas especificas e paciência. GSM/CDMA/16, 32 OR 64 GB/Black or White.
2193 Perguntas Visualizar todos
What all parts do I need to replace screen?
i need to replace the screen and back panel on my phone but i'm not sure of the right parts i need to do that. i have been reading a lot of things on here and basically says i need a lcd digitizer and screen panel and then just the back panel but i was told that the lcd digitizers are different depending on what carrier it is through so now im confused on what to buy for sure!
Esta é uma boa pergunta?
Pontuação -1
1 comentário
yea after all the reading i have been doing that's what i was shooting for thank you so much for your help.
por
Adicionar um comentário
1 resposta
Solução escolhida
Hi
For iPhone 4S there is only one display assembly that comes its irrespective of the carrier.
The back panel is also same for all iPhone 4S in the World and irrespective of carrier.
you may need different types of screwdrivers unless you have them.
You can have a look at the display assembly here and just below the pic of the display assembly you have the required tools you may need soo you can cross check it with what you have.
If you think i answered your question please rate (score) and mark it accepted. :)
Thanks
Imagem de iPhone 4S Screen
Produto
iPhone 4S Screen
$34.99
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
babyhewwy4 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 955
