Ir para o conteúdo principal
First-generation Apple iPad with 3G capabilities. Model Number A1337. Available with 16, 32, or 64 GB of storage. Repairs are straightforward and do not require heat.
71 Perguntas Visualizar todos
Are the ipad 1 and ipad 2 lcd panels interchangeable?
Question as above. I have an iPad 1 with the grey band issue, and I was wondering if an iPad 2 lcd will work. I know they are the same resolution, but is there any cable length difference between them?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
No.
The iPad LCD is attached to the Digitizer with 5 T5 Torx Screws.
The iPad 2 LCD is attached to the rear housing with 4 Phillips Screws.
Esta resposta foi útil?
Pontuação 0
NO. They are NOT compatible.
Pontuação 0
Adicionar a sua resposta
Paul Masterson será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 5
Últimos 30 dias: 11
Duração total: 2,176
