Ir para o conteúdo principal
An easy to use home Espresso machine created by Saeco and rebranded for Starbucks. This machine is excellent for every day espresso drinkers and has an excellent build and product life.
Unit not heating up.
Am following the boiler step by step guide. Checking the leads for voltage; there is none. However, when the steam button is on, there is voltage. Question; what is the diagnosis. I determine the boiler is not deficient. Could it be a switch, fuse, or thermostat? Please advise.
Regards,
Brett
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Check the boiler heating element for continuity as well as the fusible link attached to the top of it. If either is open that's your problem, and hopefully it's the fuse as that's much easier/cheaper to replace.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Brett será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 898
