Graphics Card fan speed
I have a 2006 Mac Pro. It is a 2.66 quad core, with 2gb of ram and a ATI Radeon HD 3870. It runs fine but the fan on the graphics card runs at full speed and is really loud. Is there any way to slow it down?
Update
The card is almost new. No dust. Would you recommend any fan control software for ATI graphics cards. I already have SMC fan control but it does not have the option to control the Graphics card fan.
Update
Heat isnt an issue. From cold, as soon as I hit the power button, the GPU fan starts running at full power.
Esta é uma boa pergunta?
3 comentários
I'm not a lover of forcefully controlling fan's when they are doing what they are designed to do. SMC fan control make sense on the '11 iMac's because of the incomplete SMART standard on how systems access internal HD heat sensors. Many newer drives now follow Apple's method so this is less of an issue.
por DanJ
Why are you using SMC on your Mac Pro? You shouldn't need it, and using it may cause your system to over heat. Again, get some temperature monitoring software like Temperature Gauge which you can access via the Apps Store.
por DanJ
Then, clearly the ATI card has a problem. What did you have in the system before. What does it do?
por DanJ
