Ir para o conteúdo principal
iPhone de quarta geração lançado em 2010. O reparo é simples, mas o vidro frontal e o LCD devem ser substituídos juntos, como uma unidade. GSM / 8, 16 ou 32 GB de capacidade / Modelo A1332 / Preto e Branco.
2375 Perguntas Visualizar todos
Why is my iPhone 4 taking such a long time to reset?
I recently got a iPhone 4 as a hand-me-down and since there was stuff on it, i erased all content and setting. Once i did that the screen went blank and a spinning circle appeared. However, this screen has been there for over 14 hours now. Help?
Esta é uma boa pergunta?
Pontuação 5
1 comentário
My power button doesn't work what do I do?
por
Adicionar um comentário
3 respostas
Solução escolhida
you probably have to hard rest iphone (keep pressing the home and power button together for like 10 sec or till the apple logo comes back again ) and put it in DFU mode and then try restoring it back again.
For putting it in DFU u can follow up links on internet its easy . . . .
Hope it helps :)
Esta resposta foi útil?
Pontuação 2
6 comentários:
Thank you for your answer! :D
I tried it but the apple logo doesn't appear even after i hold both buttons for quite a while.
por
okay
did we tried exactly shown in this video :-
http://www.youtube.com/watch?v=w6bqYHg2d...
por
but how if my power button is broken?
por
Same happened with me... Apple logo is coming .. Now can you tell me wht to do
por
Done.... Thnk u
por
Exibir mais 1 comentário
Thanks, It Works .
I try to delete all data and reset my iphone 4 .
I waiting for 3 hours and the screen still blank and spinning circle appeared.
I tried to keep pressing the home and power button and apple logo appear .
But still the same I think I should connect to PC via ITunes to reset it.
Thanks Again :)
Pontuação 0
Im resetting my lphone 3g and it taking a while what should I do if it still doing it in a couple of hours time Still its been 2 hours so far
Pontuação 0
1 comentário:
Different phone, different issue, Ask a new question. It's best not to stick a tag on an accepted answer question as they seldom get seen and it makes the Q&A confusing.
por
Adicionar a sua resposta
blahh será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 19,262
