Ir para o conteúdo principal
A linha de laptops MacBook Pro da Apple foi concebida para usuários avançados e profissionais. Atualmente, a linha MacBook Pro inclui as variantes de 13, 14, 15, 16 e 17 polegadas, com revisões maiores definidas pelos designs Pré-monobloco (original), monobloco, tela Retina, Touch Bar e SOC (system-on-a-chip).
20012 Perguntas Visualizar todos
Pergunta encerrada
Keyboard backlight does not light, even after replacement.
I bought a used MBP, Early 2008 Macbook Pro 15". A1226, that came with a French keyboard, and the backlight was intermittent. I replaced the KB with a US one, and that works fine, except for the backlight.
When I use the F5/F6 keys, the [on-screen backlight] indicator moves, but no change in the light. In System Preferences I have tried automatic and manual control for the backlight - no change.
Nothing is blocking either the speaker grille or the webcam area.
Ideas?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Fixed it.
It turns out that the keyboard backlight connector is very position-sensitive. I went back in and reseated all the keyboard-related connectors (again!) and was finally able to get the backlight working again.
Tim O
Esta resposta foi útil?
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 643
