Ir para o conteúdo principal
Why does the screen turn black after a while after starting
When I turn on the computer it functions for a while. The the the screen black out and a must restart the computer. When the computer starts again the same thing happens.
What could be wrong and how could i be repaired ?
Esta é uma boa pergunta?
Pontuação -1
1 comentário
Hello machead3
thank you once again for your answer. Could you help me once more by telling me how I get hold of an inverter for the machine and how I install the inverter in this type of machine.
Yours sincerely
Erling
por
Adicionar um comentário
1 resposta
Solução escolhida
Sounds like your inverter is going bad. Once it gets hot (or a failing component gets hot) you lose your backlight. Replace the inverter.
If this Answer is helpful please remember to return and mark it Accepted.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
erlingjensen será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 259
