Ir para o conteúdo principal
A mini tablet computer designed by Blackberry and manufactured by Quanta Computer in 2011. Model number RDJ21WW.
35 Perguntas Visualizar todos
Wifi very weak after screen replacement
I follow the instructions described on this site to replace me broken digitizer, but after the full assembly i got a very weak wifi signal, so weak that i have to go above the router to connect!
what goes wrong?I didn't miss to reconnect anything due to the assembly....where is the antenna in order to check it out again..
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
5 respostas
Pergunta mais útil
Hi Vasilis,
This posting might be helpful.
Have you rebooted your PlayBook yet? It might help (--> on the Playbook, press the power button and both Vol + - buttons for 10 seconds).
Steffen
Esta resposta foi útil?
Pontuação 1
Hey
I am having the same problem. Would be nice to know if you found a solution?
regards
Pontuação 0
actually i read this post > http://forums.crackberry.com/blackberry-...
and it was very usefull...and the picture witch came with..
the problem was that the wifi antenna (black coaxial cable) is vary sensitive and i was broken it.
The antenna location is at the top right side of plabook, if you looking at from the back side(witch the logo of bb locate) and is actually above the speaker witch is not removable..(the left speaker is).
what you have to do:
1)open the back cover and remove the screws to release the right speaker
2)remove the tape witch prevent speaker to move in order not to cut the cable of the speaker
3)locate the antenna witch is on the speakers top right corner and check if it's broken
it looks like this
4)the cable is coaxial...so the outside cable is negative and is in touch with the small metal chassis (witch is difficult to be broken) and the inner is the positive and it's very very fragile....you can see in the pic!!THERE IS THE PROBLEM.. it maybe broken...
now....you have to connect again with the chassis with an iron solder (that i was do)it is difficult but you can do it without buying a new antenna witch is more difficult to replace it.
You must have in your mind that you have close the circuit and negative and positive of the antenna must be at the same chassis.
tools you need is (except the tools to open the back case witch is necessary) an iron solder with solder wire and an electronic poly-meter in order to check the right assembly
unfortunately I didn't record a video during the process
ps. very sorry for my bad English.
Pontuação 0
I had the same problem where the wifi signal was very weak or non-existent. I found Vasilis' post and re-opened my PlayBook. I locatedthe antenna and found it was detached. I soldered it back and that fixed the problem.
Thanks
Rob
Pontuação 0
does anybody have an image where I can see the name of all the connectors??? im trying to figure out whats the gray connector that lands almost beside the blue connector.
thanks!
Pontuação 0
1 comentário:
(Viewing from the back):
Top Left (White Wire) - Wireless N
Top Right (Black Wire) - Wireless G
Bottom Left (Gray Wire) - GPS
Bottom Right (Blue Wire) - Bluetooth
por
Adicionar a sua resposta
Vasilis Karachontzitis será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 7
Duração total: 3,509
