Ir para o conteúdo principal
The HP Pavilion dv2000 Notebook PC is an entertainment based PC produced in 2007.
23 Perguntas Visualizar todos
Pergunta encerrada
My computer displays "Failed to create E:\sdv.flg error" what to do?
I tried to reboot my computer and when I used the first install disk from HP, after about 4% of it being complete a message pops up saying "Failed to create E:\sdv.flg error". I was wondering what the issue is and how to fix it. The computer is less than a year old and tech support was no help from HP. I was on hold while they tried to figure out what was happening for 45mins and came up with nothing
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
It sounds like you are trying to restore the operating system from the restore cd. Is this correct?
Possible cause of failure durring the OS restore could be a scratched or dirty cd, bad RAM or bad hard drive.
Double check the CD that it is clean and has no scratches.
To test for bad RAM and hard drive I believe there is a test inside the BIOS, which you can access by pressing the proper key right after turning on the computer.
If there isn't a tool to test RAM and hard drive in the BIOS, if you have access to another computer, you can find download and burn the Ultimate Boot CD, which has a RAM (Memory) test, and hard drive test.
Esta resposta foi útil?
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 5
Últimos 30 dias: 5
Duração total: 487
