Ir para o conteúdo principal
iPhone de quarta geração lançado em 2010. O reparo é simples, mas o vidro frontal e o LCD devem ser substituídos juntos, como uma unidade. GSM / 8, 16 ou 32 GB de capacidade / Modelo A1332 / Preto e Branco.
2396 Perguntas Visualizar todos
unassembled my iPhone now cant put it back together
i dropped coffe on my iphone and i installed a new screen but the problem is which screws go where and the worst part is two screws are literally stuck in ther they wont budge what can i do and if i take it to a repair shop approximately how much will they charge? please help me i used all my saving to buy that phone and i have soo many important numbers and pictures in there
Esta é uma boa pergunta?
Pontuação -1
1 comentário
Did you use a screw mat, or at least mark which screws came out of which part?
por
Adicionar um comentário
2 respostas
Pergunta mais útil
You could check the guides, all the screws are reported with they size, then you can use a caliper to find out which one you need there.
If you followed the "Display Assembly Replacement" guide ( iPhone 4 (GSM/AT&T) Screen Replacement ) you should have:
2 pentalobe screws
1x 2,5 mm (the guide says that sometimes are two)
1x 1,2 mm
1x 1,9 mm
3x 1,6 mm
1x 2,3 mm
2x 1,4 mm
1x 4,8 mm
2x 2,4 mm
1x 6,0 mm
4x 1,5 mm
6x 1,5 mm (large headed with washers)
There are 23 screws (and 2 pentalobe).
Hope this helps.
G.
Esta resposta foi útil?
Pontuação 1
This is how I stripped my very first iphone a long long time ago. I got a piece of a4 paper, and with a ruler and pencil made a rectangle shape on the paper to replicate a phone.
I then took out each screw, and placed it on the paper and stuck a piece of selotape over the screw to stop it moving , and marked each screw to where it came out of, ie camera charging docketc etc. The first phone i stripped was a 3gs, to replace the rear case.when i bought the rear case and fitted any parts (volume button) that had to be put on before the bezel could be glued on to the new rear case.I then put the phone back together with no problems whatsoever, as i knew every single screw went back exactly where it came from.
If i were you, i would buy a brand new complete screw set around £2.00 in the uk, and then go on you tube and study as many stripdown vids as possible, and the reversal of that same procedure, and if you take your time, you will get it back together..Keep away from a repair shop, as they will charge a fortune
hope this helps
Dave....
Pontuação 0
Adicionar a sua resposta
edithdominguez53 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 3,170
