Ir para o conteúdo principal
Released June 2009 / 2.66, 2.8, or 3.06 GHz Core 2 Duo Processor
300 Perguntas Visualizar todos
Airport Card - Antenna connector broken
Hi Guys,
I just broke my Airport Card Antenna connector from the Airport Card. There are 2 connectors - "J1" and "J2"
J2 is fully broken from the airport card, but the WiFi is still working. Do you have any idea what is the "J2" connection for...? is it just for boost the signal ?
Thanks!
Esta é uma boa pergunta?
Pontuação 1
3 comentários
Have you tried your bluetooth connection to see if it's still working? I believe the Airport antennae also handle bluetooth, but I'm not sure.
por
Yes, both working.
Here is a photo from the broken part:
http://www.herbalfire.com/1.jpg
por
Hmm, I can't feel any changes in the strength of signal.
por
Adicionar um comentário
2 respostas
Solução escolhida
I think there are two antennas located in the MBP display. You're getting a signal probably because one antenna is still connected to the airport card.
Esta resposta foi útil?
Pontuação 1
I think one of the connector is exclusive for 5Ghz operations, or both connectors are dual band, losing one just means losing a MIMO chain. It only impacts top performance, which is rarely approached.
Pontuação 0
Adicionar a sua resposta
csaba será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 9
Duração total: 1,770
