Ir para o conteúdo principal
Can I get the warranty reinstated by Apple after soda spill?
Spilled soda on keyboard. This voids my warranty. The keys in the left lower corner pop, but is still functioning after 2 months, besides for the key popping, and my shift key lock which getting stuck in on position and does not return to original position after pushed, there is no other problem.
If I can get an Apple to recommend a person to repair and if the water damage is limited, is it possible for Apple to reestablish the warranty?
Thanks
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
You may want to contact Apple directly, as they would be the ones to tell you if that warranty is able to be reinstated. Chances are that they will tell you no, but you can always contact them to find out.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
bob será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 172
