Ir para o conteúdo principal
A 10.1 inch Samsung tablet computer with a 1.4 GHz processor, 1280x800 pixel LCD, and 149 ppi multi-touch display. The model number of the device is GT-N8013ZW. Released August 2012, repair of this device is straightforward.
Why can't I connect to a wifi network?
my Samsung Galaxy 10.1 tablet suddenly stopped connecting to my wifi modem. I get momentarily connected with an excellent signal, but the tablet keeps trying to reconnect and doesn't stay on.
Samsung service says that they can fix it remotely, for $100. for a month of coverage.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
It sounds like the 'Samsung Support' that you spoke with may not actually be from Samsung, if they are going to charge you $100 a month to keep your WiFi working. I would recommend getting in contact directly with Samsung here.
It may be possible that it is software issue. Have you tried doing a factory reset? If that doesn't solve it, it may be a hardware issue.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Ray será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Ao todo: 2,793
