Ir para o conteúdo principal
Released in Late 1993, the Macintosh Quadra 610 and Macintosh Centris 610 are two closely related personal computers that are a part of Apple Computer's Quadra and Centris series of Macintosh computers, respectively.
4 Perguntas Visualizar todos
How do I fix the resolution on my screen?
I just got my macintosh and booted it up and the screen said the resolution was out of range, control panel doesn't open.
also I want to remove the previous owners files, should I reinstall the system? (i have reinstall disks from my powerbook 100 that may work)
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
First check to see if the video RAM slots are filled. Two internal Video RAM slots can take either two 256 kB 80 ns 68-pin VRAM SIMMs, or two 512 kB SIMMs. Installing one 512 kB and one 256 kB VRAM SIMM garbles the display. See if you can find, then press the reset button on the logic board. Did you replace the 3.6 volt PRAM battery? Next try zapping the PRAM (command - option and P and R keys held down on start up.)
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Ted Mayer será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 319
