Ir para o conteúdo principal
Poor WiFi range on my iPhone 5
My 4 months old iphone5 have poor wifi signal if i 4-5 meters close to my router, but when i out from that range signal are lose and my iphone cant see wifi from this distance. After that when i again close near my router to 1-2 meter wifi network showing but only one bar :(
I was try all solutions from net (restoring, all kind setup of my router, reseting iPhone, resseting network settings.)..and nothing
I reading some post from this site and my conclusion is that could be a hardware problem with my wifi antenna connection ... Anyone with experience to give me advice????
Is this correct wifi circuit (red line on pics)
Esta é uma boa pergunta?
Pontuação 7
4 comentários
PROBLEM SOLVED FOR ME ALLHAMDULILLAH
After sending my phone to Germany , cannot get replacement from Apple. Today i was in the service in my town and afer detaching motherboard , guy spotted disconnected little tiny resistor from inside side of motherboard. Any way after he is connect this little resistor and check all other connecters set up my iphone and afer many days with crappy wifi i have 3 bars and dont need sitting next to router.
My advice. For you who are living near Apple store and you buy your iphone in this country (Apple dont have international warranty ) go and get replacement......
BUT all of you who are like me livin in crappy country without apple store. go to respectabile service and check all conections bcs THIS IS HARDWARE PROBLEM ......
(I was talking about poor wifi range )
GOOD LUCK FOR ALL OF YOU FOLKS
por
I changed the resister on the mother board then also poor wifi signal only tiny improvement
por
I have two mobile phones one Iphone 5 16GB and other android os mobile. I was compare to each other android mobile shows many signal of wifi routers as compare iphone. Any Solution regarding iphone please share with us
por
i have reset wifi routers and change some settings and now its work for me.
por
Adicionar um comentário
5 respostas
Pergunta mais útil
I have the same exact problem for like a year I'm using 3G the whole time. I tried everything but no way. There's no apple store in my country too :/ I've given my iphone to an expert and he told me that everything looks good inside the phone. Anyone willing to help?
Esta resposta foi útil?
Pontuação 1
1 comentário:
i want to help i have same problem . when i sit close to wifi router then wifi connected on Iphone 5c . when i walk 5 feets then not in range or searching and then nothing search any wifi.. plzzz help... plzzzz help?.. THANKX
por
Your phone is still under warranty. I would recommend talking to Apple to have them fix it or get a replacement. It does sound like a hardware issue. Has the phone been dropped?
Pontuação 0
1 comentário:
No, iphone never dropped . Im from country which havent Apple store,but i send my iphone to Germany for replacement. If apple denied my request, i will open my iPhone and check connection of my wifi antenna because all symptoms leading in that right ..
por
so there's no way to repair iphone5?
Pontuação 0
Did you tried the Linkase?
Pontuação 0
Did you Hard Reset your iPhone ...
Try to do that by pressing "home button + lock/power button"
It solved same problem of mine..
Pontuação -1
1 comentário:
like problems?
por
Adicionar a sua resposta
edin será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 46,594
