Ir para o conteúdo principal
Repair information for tools used for specific tasks like fixing, building, or cutting. Learn how to use tools that work to fix the ones that don't.
2231 Perguntas Visualizar todos
Pergunta encerrada
I've had to deal with recessed screws while disassembling a laptop
I am going to purchase either the Home tech Toolkit or Pro Tech Toolkit (depending on finances) soon.
I also need a small assortment of philips-head screwdrivers that can hold a screw upright while putting it into a recessed place -- way too deep to hold on with my fingers. Enough room for the screw to fall over, but not enough room to put tweezers in with the screwdriver.
It doesn't look like either toolkit has these, and I can't imagine that you don't sell them. Please point me to the right product.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi Maggie, thanks for your question! The bit kits included in the [produto vinculado ausente ou desativado: IF145-047] and [produto vinculado ausente ou desativado: IF145-072] each contain a 60 mm driver extension that may allow you to reach into recessed screw holes.
However, in some cases this isn't thin enough—for those situations you'll need a fixed driver. We sell these for every Phillips size, that can be magnetized to hold onto screws. For laptops I'd recommend a Phillips #1 and Phillips #0. For really small recessed screws, you'll need a Phillips #00.
Imagem de Phillips #0 Screwdriver
Produto
$5.49
Imagem de Phillips #00 Screwdriver
Produto
$5.49
Imagem de Phillips #1 Screwdriver
Produto
$5.49
Esta resposta foi útil?
Pontuação 1
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 5
Duração total: 1,230
