Ir para o conteúdo principal
O PlayStation 3 Slim é a segunda versão do console PS3 com o primeiro número de modelo sendo CECH-2000. Produzido pela Sony Computer Entertainment, ele corrigiu muitos problemas da primeira versão do PlayStation (Fat). O Slim foi lançado no dia 1 de setembro de 2009.
465 Perguntas Visualizar todos
Blu-Ray Disc Wont take disc?
I am working on my ps3 i followed the "Installing PlayStation 3 Slim Blu-ray Disc Drive" guide to take it down and i looked up some other videos to take apart the blu-ray drive. I need help on fixing the Blu-ray drive. i can take it apart but i need help knowing what to do to fix the player. right now the player will not suck in the disc but i can put a disc in manually but nothing will happen. the only thing disc will do is eject. Please help me.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
3 respostas
Solução escolhida
If you know how to take apart the drive, remove the metal shield and the second layer. Once that is removed you should see a gear mechanism in the bottom right corner. Look at it and make sure it is engaged to the sprockets. If not, there is a release with a spring on the left side that you will have to turn to release the black platform. Now re-engage the drive mechanism by pushing it against the white sprocket, while turning the sprocket. Once it's back together reassemble and test.
I've found this to be one of the more common issues for the problem you described.
Good luck, and let us know how it goes...
Esta resposta foi útil?
Pontuação 3
1 comentário:
im a girl with no help from any guys can you please walk me through the process i already have the metal shield and the second layer off
por
The above answer worked for me when all hope was lost thank you!
Pontuação 0
1 comentário:
could you help me with this i already have the shield and the second layer off
por
I took my ps3 apart to fix it and its still not reading disc and its making ejection noise
Pontuação 0
Adicionar a sua resposta
Theodore Osbourne será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 15
Duração total: 8,203
