How do I test the power supply?
i have an unresponsive intel imac and i was wondering if there is a way to "jump start " the power supply so that i can see if it is functioning with my meter and maybe a pinout . also are there any good sources for apple component level repairs like board repair ? the only thing i have found so far is the g5 imac info about cap replacement
-thanks in advance
Esta é uma boa pergunta?
1 comentário
== Unresponsive, How? ==
Can you explain specifically what you mean by an "unresponsive intel imac"? If it isn't booting up, there could be some reasons other than the power supply. For example a loosely seated stick of RAN can probably stop the machine from booting. A better description of the symptoms are needed here, and of the steps you have taken to discover the true cause of the unresponsiveness. Thanks. --Bob
por cochranb
