Ir para o conteúdo principal
The current line of iPod touch comprises seven (7) different generations.
2619 Perguntas Visualizar todos
Pergunta encerrada
Sleep on/off Button no longer works
I was using my iPod while exercising - I didn't have a holder, so I put it in my bra where I sweat on it.
The device was in a silicon sleeve which I guess held the sweat on the case. The button worked sporadically for a month, but now the on/off button will not work.
I have to wait for the device to "sleep" and I cannot shut it off.
Esta é uma boa pergunta?
Pontuação 0
2 comentários
I noticed you never got an answer to this. Are you still having this problem?
por
Machead, thank you for the suggestion but the real issue is that I beleive the sweat got into the on/off switch and screwed it up. I don't know how to clean the contacts off (prolly will have to find a tech to take it apart, it's out of warranty).
I tried pressing the menu and on/off button, but since the on/off is not working, nothing happens. :(
por
Adicionar um comentário
2 respostas
Solução escolhida
Try this
  • Press the Menu button + the middle button altogether until the apple logo appears.
  • If this doesn't work do backup then a restore to factory settings in iTunes settings
If this answer was helpful please remember to mark it accepted.
Good Luck,
N
Esta resposta foi útil?
Pontuação 0
yes, I still have the problem....i have to let the ipod "time out" and shut itself off.
Pontuação 0
1 comentário:
Please post this comment as an Update to your Question only Answers belong here.
por
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 785
