Ir para o conteúdo principal
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Perguntas Visualizar todos
iPod wont stay on when not plugged in
hi i lent my ipod touch 4th generation to my friend and he acidentaly washed it in the washing machine and at first i thought it was fine i just thought the battery died so i plugged it in and it turned on but when it sayed it was charged i unplugged it and it turned off not sleeping but turned off i plugged it back in and it turned on so i thought there was something wrong with the battery so i replaced it and the screen because that needed to be replaced anyway so i did all the steps correctly i soldered the battery right and everything what could be the problem? thanks
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Okay, just to clarify, it turns on and works okay when plugged in, but does not work when unplugged?
por
Adicionar um comentário
1 resposta
Solução escolhida
Hi Edward,
I would first check the battery. See my problem and the solution offered here:
After water damage: Repairing charging circuit?
However and under your circumstances, I would also remove the motherboard, let it soak in isopropyl alcohol (90%) for 15 minutes and then let it dry for a couple of days before I would built it in again. It is possible that there is still some water from the washing machine or moisture somewhere on the motherboard or under metal covers where you cannot see it. the isopropyl alcohol would take care of that.
Consider that your iPod was extremely shaken by the washing machine, and a good amount of water went probably into the iPod via the headphone jack or dock connector.
But to be really on the safe side: I would also disassemble the rest of the iPod as much as possible (just follow the guide here on iFixit) and then let it dry near a air conditioning fan. After that, I would assemble everything.
You might give it a try. It would only cost you $2.50 for the isopropyl alcohol.
Steffen
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Edward Rae será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 2,926
