Possible Soundcard Issues, identifying which part to replace.
Hi there,
My early 2008 macbook pro A1260 2.5 is experiencing some problems. The main problem is that the sound card(I believe its the soundcard as the sound comes from internal speakers and headphone out) behaves very strangely. Sometimes it works fine but around 1/3rd of the time it will just give off static sounding noise, popping and cuts out while listening to any source of audio.
The laptop also will not stay on without the battery present and will not switch on either if he battery is missing. The battery appears to be fine and the magsafe is a 3rd party new one which definitely works. I have another A1260 laptop with a logic board that is 100% working so I am wondering if I should replace this in my current laptop or is it more like to be the left i/o board?
I checked he balancing left/right via preferences and the sound remains the same on both channels.
I have made a recording of it here, https://soundcloud.com/colin-mackay/nois... (can hear it clearly after about 2/3 seconds in, the static sound + popping). I am certain it's not blown speakers.
Any help would be much appreciated!
Esta é uma boa pergunta?
5 comentários
your computer probably goes to sleep without the battery because you probably got a 60W charger instead of the 85w
por Alfy
Would you mind giving us a link to support this statement?
por mayer
I know from experience. I guarantee if you use a 85W charger it won't go to sleep regardless of having the battery in or out.
por Alfy
I some how don't believe you.
por John Laney
Hi there,
It is definitely an 85w charger, it isn't however an apple brand one so this may have something to do with it.
por Colin Mackay
