Ir para o conteúdo principal
Repair guides for the MacBook.
3787 Perguntas Visualizar todos
My battery does not work any more
I have a MacBook, three or four months ago it fall water over it and since, the MacBook does not recognize its battery any more so I have to use it only with electric power. I took it over service and they told me that some "electronic component" is not working. Where can I get the part that alows the computer to recognize the battery again? (I don't know the name of the component)
Thank you very much for the information you can give me.
Esta é uma boa pergunta?
Pontuação 2
1 comentário
my Battery is not working as well i need help plz i don't own the gopro i have so i need some one to fix the Battery
por
Adicionar um comentário
1 resposta
Solução escolhida
Hi! It sounds like you may have a faulty battery connector. I would suggest identifying your MacBook via our ID Your Mac page and then use the appropriate guide to replace the battery connector. If you have a MacBook Core 2 Duo, use this guide. If you have a MacBook Core Duo, then use this guide. Hopefully this helps out.
Imagem de MacBook Core Duo Battery Connector
Guia
MacBook Core Duo Battery Connector Replacement
Nível de dificuldade:
Moderada
Imagem de MacBook Core 2 Duo Battery Connector
Guia
MacBook Core 2 Duo Battery Connector Replacement
Moderada
Esta resposta foi útil?
Pontuação 3
2 comentários:
Since the unit has had water on/in it I wonder if the battery could of shorted out and no longer be functional. Perhaps the OP could try a different battery and see if that works. Ralph
por
I've very rarely seen the connectors fail. I would do as rj713 recommended. But the answer by Walter is the kind of documentation I like to see and almost got an upvote form me. Maybe a bit of editing would make it better.
por
Adicionar a sua resposta
nataliagonzalezortiz será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 2,100
