Ir para o conteúdo principal
Versão renovada do iPhone 3G com velocidades de processamento mais rápidas. O reparo deste dispositivo é semelhante ao do 3G e requer simples chaves de fenda e ferramentas de abertura. Modelo A1303 / 8 GB,16 GB ou 32 GB de capacidade / Parte traseira em plástico preto ou branco.
1502 Perguntas Visualizar todos
Pergunta encerrada
Is 70% Isopropyl alcohol ok to clean an iPhone 3GS?
I was caught in a heavy rainstorm about 3 days ago and my iPhone died on me. I opened it up when I got home and dried off the components with a soft cloth as well as ordered a new LCD & Digitizer and installed those.
The screen works as it should but the backlight is still inactive.
My question is: Is 70% isopropyl alcohol enough to clean the logic board and connectors of the 3GS? I was planning on following the guide posted on this website inorder to do the fix but was just wondering if 70% was too little of an alcohol concentration.
Thank you for any help you may be able to provide.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
No. 70% isopropyl is 30 % water. Use methanol.
Esta resposta foi útil?
Pontuação 2
6 comentários:
So if I were to soak or brush the contacts with it it would just ruin the phone further? Also, would 90% or 99% be the right choice then?
por
90% + should be fine.
por
And 90%+ is available at places such as Target or Walmart correct?
por
Andrew Novotny, I get my stash of 99% through my local pharmacist. The larger retail stores are not really good in getting those items, not a big selling item for the.
por
I don't know, I use Methanol. Call them.
por
Exibir mais 1 comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 4
Duração total: 1,698
