Ir para o conteúdo principal
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
152 Perguntas Visualizar todos
Pergunta encerrada
Why is my ipad 2 not response when I touch the digitizer?
Hi all i have a broken digitizer on my ipad 2. After replacement able to power up but not responsing when i touch any area of the screen. Unable to slide to unlock. Initially thought was the new faulty digitizer that i had bought online but after i got the 2nd replacement the issue is still remains. Can any kind souls help me on this issue? I have tried reset all settings and ios still the same issue. Thank you.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Where did you buy the Digitizers ? You could have bought 2 bad ones depending on where you got them.
por
Adicionar um comentário
2 respostas
Solução escolhida
Two things. Either a bad digitizer or you damaged the digitizer connector on the motherboard when you connected it.
Esta resposta foi útil?
Pontuação 0
I would avoid buying digitizers on eBay, as I'm sure most of them aren't run through a quality control check. I bought one on eBay a year ago for my iPad and about 2-3 months later dead spots started occurring on the digitizer. When I received it, I thought it felt kinda flimsy compared to the original digitizer. I recommend buying from a quality provider like etechparts.com as they have weeded out the Chinese companies that provide garbage products. I just recommend spending a little extra money and get the iBic digitizer. All parts from etechparts come with a 90 day warranty.
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 460
