Ir para o conteúdo principal
Home button seems to be pressing by itself?
The home button on my iPod Touch seems to be pressing by itself.
If I open any app it will just close after a few seconds as if I pressed the home button. Also, when I'm not in an app it will just flip back and forth between the search screen and the list of apps as if I was pressing the home button.
The button does not seem to be physically jammed because when I do press it you do feel and hear it click. And the button does work.
One other note..if I press down either to the right or left side of the home button it does act as if I did press the button.
Any ideas on this? Thanks.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
If this is a 3rd generation Touch, I'd take it back to Apple, as it should still be under warranty.
Esta resposta foi útil?
Pontuação 1
did you find a solution? myn is doing the same.
Pontuação 0
1 comentário:
Edited to remove email address (for security reasons
por
Adicionar a sua resposta
Keith Maurino será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 4,191
