Why light won't go out and load won't start?
The light won't go out when the door is closed. Put a load in and it will not turn on.
Esta é uma boa pergunta?
Terry G, try to push the door switch button and see if the light goes off in the dryer. It is possible that this is caused by a bad door switch. You can check it for continuity with an ohm meter to make sure.Download the service manual from here for more information.Page 4-3 shows you how. If you are more of a visual person, check on here and here as well. Hope this helps, good luck.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 331
