Ir para o conteúdo principal
Nº da peça HP: CN731A#B1H: impressora, scanner, copiadora, navegador da web com capacidade de internet sem fio
Why is my printer printing only partial lines?
When printing text, the printer is printing only the top half of the lines, on each line. The printer cartridge is still half full and even though I changed it out it is still doing the same thing. I have even tried to do a new alignment. Any suggestions?
Esta é uma boa pergunta?
Pontuação 3
1 comentário
I have a hp printer deskjet 1000.i've already bought a new ink cartriges and install in my printer.when I print some photo theres lines on it.please help me.
por
Adicionar um comentário
3 respostas
Solução escolhida
Probably your printer head is jam you can try by taking out your cartridges and put your cartridge heads in semi warm water for like 5 minutes. And try to blow some air in the ink holes on the top of each cartridge. Hopefully this shall clear any blockage in heads.
Esta resposta foi útil?
Pontuação 3
2 comentários:
I have used new cartridge still same I suspect paper caught
por
I have had to rip paper out printer a few times
por
clean printheads if no avail time to get a new printer
Pontuação 1
My deskjet 2630 keeps skipping lines of print I have cleaned the cartridge but still does the same thing
Pontuação 0
Adicionar a sua resposta
dawn a será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 27
Ao todo: 42,338
