Ir para o conteúdo principal
2.5 GHz dual-core Intel Core i5 processor (Turbo Boost up to 3.1 GHz) with 3 MB shared L3 cache.
265 Perguntas Visualizar todos
Is the SSD disk the same in MacBook Pro 13" and 15"?
Hi!
Is there any differences between the SSD discs on 13" and 15"?
My 13" retina got jägermeister all over and died completely. Now I'm buying a 15" retina and I want to know if it's possible to replace the hard drive with the one in the broken 13" so that i don't loose all my valuable data.
Best regards,
Mikkel Christiansen
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Solução escolhida
OWC makes a Envoy drive which you can put your stick in an read it via USB. They make a couple of different ones for the different sticks so check before buying. You can then transfer your data and use the old stick for storage. I think this is the one you need: http://eshop.macsales.com/item/OWC/MAU3E...
Esta resposta foi útil?
Pontuação 2
After reviewing the applicable teardowns, I see no reason why you couldn't swap drives. That being said, the 15" comes with twice the storage, so I'd recommend just transferring said data to your new Mac.
Cheers!
Pontuação 0
Adicionar a sua resposta
Mikkel Christiansen será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 4
Duração total: 483
