Ir para o conteúdo principal
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
250 Perguntas Visualizar todos
Ipad 2 not charging after digitizer replacement. Any ideas?
I've just replaced the front panel and digitiser on an iPad 2 Wifi. I've been using it for a few hours and battery life has depleted at its usual rate. When plugging it into the mains or laptop it doesn't show as charging or hold any charge.
I've tried turning off and resetting but have been unsuccessful.
Has anyone else had a similar problem or is able to give me any advice?
I'll be opening her up again tomorrow to have a closer inspection.
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Many thanks for the replies.
It was indeed a damaged charging dock connector. Fortunately it was a £3.99 fix.
Thanks again
por
Adicionar um comentário
4 respostas
Solução escolhida
Hi
As mentioned above if you are using a metal spudger to get the old screen off, you may have gone through the charging dock cable, however before removing this new digitizer, please ensure you try another charger in case the current one is faulty
Regards
Ali
Esta resposta foi útil?
Pontuação 0
Pergunta mais útil
see if you disconnected charging port cable or damaged it by any chance
Pontuação 1
cheak the power cable if there is any small crack , when you open the digitizer maybe you dameg it it is located near the volume switch
Pontuação 0
hiya i wonderd if you can help me i have took the digitilzer off a ipad 2 wifi and the plastic bits where the digilizer cable goes in has come off n how do i put them bk on or does it affect it without them please can you email me on fozzy58@outlook.com
Pontuação 0
Adicionar a sua resposta
Robo será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 3,298
