Ir para o conteúdo principal
Quinta Geração do Iphone. A Reparação deste dispositivo é correta, requer ferramentas especificas e paciência. GSM/CDMA/16, 32 OR 64 GB/Black or White.
2193 Perguntas Visualizar todos
Pergunta encerrada
iPhone 4s won't charge
Hi!
I have a iPhone 4s that took a swim. Everything seems to be working perfectly, except it wont charge.
I have replaced the dock-connector and the battery, but nothing has turned out working. The battery percentage keeps dropping as i write.
The charging symbol shows when the cable is plugged, but the phone doesn't charge. It is not recognized by itunes either.
However, if i plug the phone into a speaker-dock, music starts playing (from the dock). The microphone, loudspeaker and homebutton is working aswell, so i cant really figure out what the problem is. Is there any other parts i should try to replace?`or is there any other method i should try?
Any suggestions are welcome! i really need this to be fixed
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
You need to disassemble your phone and treat the logic board for water damage, here is a guide for treatment on a 3G but use these methods on your 4,Repairing iPhone Liquid Damage and here is a guide to teardown your 4, iPhone 4S Teardown, good luck, If this Answer is helpful please remember to return and mark it Accepted.
Imagem de iPhone
Guia
Nível de dificuldade:
Difícil
1 - 2 hours
Imagem de iPhone 4S
Guia
iPhone 4S Teardown
Moderada
Esta resposta foi útil?
Pontuação 1
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 4,714
