Ir para o conteúdo principal
Quinta Geração do Iphone. A Reparação deste dispositivo é correta, requer ferramentas especificas e paciência. GSM/CDMA/16, 32 OR 64 GB/Black or White.
2193 Perguntas Visualizar todos
Pergunta encerrada
Dropped in water now won't ring and bell symbol missing
I have dropped my iPhone in water. It is now completely dry and everything works fine except the switch on the side that switches from ringing to vibrating. The phone will still vibrate but when switched to ringing the bell symbol doesn't appear and the phone will not ring. What part do I need to replace to repair it.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Sorry to say that if you want to take care of this right you need to do a real water treatment to it, even though most of your functions have come back they will stop working again with time and your phone will stop working all together, try this, Repairing iPhone Liquid Damage, its a guide for an I 3 but use these methods on your 4, and here is a teardown guide for your 4 S, iPhone 4S Teardown, if you do this I would bet your other problems will be fixed also, good luck, If this Answer is helpful please remember to return and mark it Accepted.
Imagem de iPhone
Guia
Nível de dificuldade:
Difícil
1 - 2 hours
Imagem de iPhone 4S
Guia
iPhone 4S Teardown
Moderada
Esta resposta foi útil?
Pontuação 1
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 2,737
