Ir para o conteúdo principal
2008 netbook; Model ZG5 AOA150-1691; 8.5" screen; 1.6 GHz N270 Intel Atom Processor
74 Perguntas Visualizar todos
I want to max-out the RAM on my ACER
I want to max out the RAM on this machine, the specification says the following:
RAM / Max RAM
512 MB onboard DDR2 533 MHz SDRAM single channel with onboard SDRAM and one soDIMM slot, with up to 1 GB/1.5 GB using one 512 MB/1 GB soDIMM module
The machine when I check my PC general says it has 0.98GB.
My question is what do I need to buy from you in order to maximize the RAM on my Acer ZG5?
Regards,
GraemeD
GDonald386@aol.com
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
You can put a 1 GB stick which can be bought here or here
Not that it will display a little less than 1.5 Gb when installed, this is due to the fact that a part of the RAM is used for VRAM.
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
GDonald386 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 5
Duração total: 1,312
