replacing 500Go with 2To
Hi all, I'm new here and I have read the guide to replace the original HDD 500Go to a new Hard drive bigger.
I have thus bought a 2To Western Digital Green , removed all the screw and replaced the original by the new hard drives.
The Time capsule power up, but stay orange. I could not get the Wifi signal up.
I let it into the box for 5/10' but as it remain orange with no wifi I was afraid that I broke it.
I then put back the original hard drive into the TC. And it worked.
What could have I done wrong ? Should that TC need reinitialize ? I pressed the little button on the rear, it start flashing but it did not help.
Thanks for help !
PS : I must precise that the HDD was never used before and has no partition/not formatted, I don't know if it has any influence.
Esta é uma boa pergunta?
1 comentário
I have powered the time capsule without the hard drive and the wifi show up. Would it be possible that the issue is with the hard drive? When I use the reinitialize function via airport utility it erase all the settings but even after the connection of the drive it does not start :(
por Jean-Mi
