Ir para o conteúdo principal
Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
591 Perguntas Visualizar todos
No audio output detected
Hi,
I have a big problem with my macbook pro late 2011 with mac os 10.7.5. The problem is : no audio device detected.
So i did all possible solutions found in forums but with no result.
If any one had the same problem and he found solution plz shar.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
You could try a USB Audio Dongle..(adaptor). USB audio runs on different chips... if the adaptor is discovered it would have line in/out ports... BTW some of the adaptors are also microphones.
If this Answer is helpful please remember to return and mark it Accepted.
Esta resposta foi útil?
Pontuação 1
2 comentários:
Thank's for your answer.
But i'd like to know if its a driver problem or material problem.
por
Sorry to delay replying - was supposed to have been notified you commented. Either I missed it, or, it's still in the aethernet.. anyway must be hardware if all the software fixes failed. There are no software fixes for hardware problems.
por
Adicionar a sua resposta
Donili será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 907
