Power button lost spring action
I tried many times to re-seat the power button but unable to make it click with spring action. I made sure that liigle rectagular tape it is in place and not too tighten the screws as suggested in other releasted questions. Still unable to make it click. HELP! ...
Esta é uma boa pergunta?
1 comentário
Solved: It turned out that the little rectangular tape (spacer) is not thick enough to push the power button out after tighten up the 2 screws that hold both on/off button and contact point. I added a couple of layers of electric tape on top of the original little rectangular tape behind the button. Problem is solved.
ifixit.com step 17 described the functionality of this little rectangular tape as "When replacing, check the protrusion of the switch. There is a small plastic spacer adhered to the inside of button which may come off with cleaning. Without a spacer, the button may not protrude enough to be depressed. If lost, it can be replaced with a suitable thickness of stiff plastic (eg shirt box lid)."
por hungtphan
