Ir para o conteúdo principal
The Apple TV is a digital media receiver designed by Apple and released on March 21, 2007
17 Perguntas Visualizar todos
Analog RCA Audio not Working
I have the Apple TV 1st Gen and am trying to use the RCA analog audio output, but no sound is coming out. I have tried connecting the RCA cable directly to the TV, into my receiver, and even tried routing it through my computer's audio, but it still has not worked.
I have googled extensively about this problem and haven't found anything extremely helpful.
In case anyone is wondering, I don't have the option of using the hdmi audio, or the optical audio. I have, however had the opportunity to test if the hdmi audio works, and it does.
Thanks.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
Adjust the audio out and dloby digital settings (settings > audio & video)
You might also try restarting the Apple TV by removing ALL the cables for 30 seconds, or resetting it using the reset option under general.
If this answer was helpful please remember to mark it accepted.''
Esta resposta foi útil?
Pontuação 1
1 comentário:
I tried all these, still no audio. And just to clarify, there is not audio out adjustment option in the audio&video menu, only the dolby digital on/off.
Thanks for the suggestions
por
Adicionar a sua resposta
korellitor será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 1,188
