Ir para o conteúdo principal
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
152 Perguntas Visualizar todos
Can I replace front panel with other colour version?
My god son dropped my iPad and front glass is completely crashed now.
I am going to order replacement parts from iFixit but I am wondering I can order other colour front panel.
I had white for almost 2 years, now it is broken and it is oppourtunity to change front colour into black, can I do this? Both colours fit to my iPad 2?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Pergunta mais útil
Yes, as long as you get the screen for the right model the color doesn't matter, when you order your screen you might want to also order a wifi antenna and the power volume flex, when the screen is cracked bad it's REAL tough to remove it without damaging these parts on the Ipad 2, good luck.
Esta resposta foi útil?
Pontuação 2
1 comentário:
Ok, I've done this.
It is thin, white, plastic line around the glass, but it's hardly notable and I have a black version now.
I've also replaced wifi antenna and buttons wire, but I've broken gsm antenna...
well I can live with this :)
here is my repair story:
http://iwear.janmazurczak.pl/repair.pdf
por
Adicionar a sua resposta
Jan Mazurczak será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 3,666
